I trust you cleaned and greased that pipe in the picture Gaz, while it was easy to get at.Forgot I had a picture of my diff hanger, it's easier to inspect without the diff fitted but you can still inspect it if you can get underneath the car...
Possibly... Probably... Maybe...I
Don't all exhausts blow T-? Don't ever recall one that sucked!! lol oh the drugs are working overtime tonight!Don't matter what it is mate. First rule of pipe work if you can clean and grease it, do, it'll extend the life of these items indefinitely. Lecture over !! You're right though she looks clean around that mounting. Coop's is looking for info on changing the auto oil on his car so I can feel another "How to" in the offing. By the way I had a 3 series 2.5 with a blowing exhaust at work today. The nuts on the front joint studs were completely corroded away letting the joint separate. I heated the flange where the "studs" were fitted until red hot and knocked them out with a hammer and replaced them with new gaskets and 4 nuts and bolts. Was reasonably easy (on a ramp admittedly).
Pretty much the same issue we found when looking under BMBabe's Panther, and why I went to the local garage to get them removed before starting on mine in @Lee's garage. Think mine were in worse condition though as it took them well over an hour to remove the 4 of them.The nuts on the front joint studs were completely corroded away letting the joint separate. I heated the flange where the "studs" were fitted until red hot and knocked them out with a hammer and replaced them with new gaskets and 4 nuts and bolts.
Did you replace yours with nuts and bolts? Obviously easier during assembly in Spartenburg but not so for later maintainance.Pretty much the same issue we found when looking under BMBabe's Panther, and why I went to the local garage to get them removed before starting on mine in @Lee's garage. Think mine were in worse condition though as it took them well over an hour to remove the 4 of them.
We'll really need to PM One another if you have any tips you can share. I learned an awe full. Lot over the time it took to get my car home. I'm corresponding with a fellow in Edmonton re a 98 zed and may need to fly out. I'll PM and see if we can get together if I do. JIMThanks, Jim! I've, fortunately, imported cars from both the US and Japan previously so I'm familiar with the paperwork and, at times, the lack of information. Weirdly enough, this is also not the first time I've purchased a car without ever driving it or even one similar, excited to see what it's like to be in and drive!
Welcome to the forum from New Jersey. FrankieHello all,
I'm located in Edmonton, AB Canada. I've owned a combined 57 motorcycles and cars including a few different convertibles, two S2000s and a first generation MX-5.
I stumbled across a Z3 2.0 with 56000kms in Japan online that captured my interest for whatever reason so I pulled the trigger. I know the 2.0 wasn't around for too long so I'm struggling to find too much information on it, the car should be on the ocean in the next few days and I should have it by the end of January or so - will be a few months before the snow melts and I can actually see what it's like to drive. Any advice or comments on these cars will be appreciated, here are a few pics:
Hey Gary........How about a link on "How to take out a contract on the guy that broke his mirror"?Sorry to hear about the wing mirror, sadly a common problem at their age and are generally best left unfolded forever now! Some useful links below which may help...
How to take the mirrors apart - https://zroadster.org/articles/bmw-z3-mirror-base-refurbishment.66/
Replacement parts supplier - https://zroadster.org/threads/bmw-z3-wing-mirror-upgrades.5674/
I can't publish those for obvious legal reasonsHey Gary........How about a link on "How to take out a contract on the guy that broke his mirror"?
Thought that was your department Godfather.Hey Gary........How about a link on "How to take out a contract on the guy that broke his mirror"?
Frankie at work (in New Jersey)
