I am having issues with my boot not locking or unlocking with the remote each and every time I use the remote.
If I use the key in the boot all the doors will unlock or lock every time like it should.
Thinking it was the loom of doom I pulled it all apart but found no issues at all. Taped it all back up and still same issue. I can predict when it is not likely to unlock. What happens is this....... When I lock with the remote the boot will often lock but makes a bit of an electronic hum sound which lasts less than a second. Sure enough, it won't unlock with the remote next time I use it. If I use the key to unlock it all doors including the boot will unlock and all is well for a little while. then the issue arises again.
I have fiddled with the loom wires to the actuator but makes no difference.
I don't understand why the key will always make the whole system work with the occasional failure of the actuator using the remote.
Is the boot actuator failed and needs replacing or can this be easily fixed?
Any suggestions?
Cheers,
Any suggestions?
Cheers,
