Boot lock problems.
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
I am having issues with my boot not locking or unlocking with the remote each and every time I use the remote.
If I use the key in the boot all the doors will unlock or lock every time like it should.
Thinking it was the loom of doom I pulled it all apart but found no issues at all. Taped it all back up and still same issue. I can predict when it is not likely to unlock. What happens is this....... When I lock with the remote the boot will often lock but makes a bit of an electronic hum sound which lasts less than a second. Sure enough, it won't unlock with the remote next time I use it. If I use the key to unlock it all doors including the boot will unlock and all is well for a little while. then the issue arises again.
I have fiddled with the loom wires to the actuator but makes no difference.
I don't understand why the key will always make the whole system work with the occasional failure of the actuator using the remote.
Is the boot actuator failed and needs replacing or can this be easily fixed?
Any suggestions?
Cheers,
May be worth removing the boot solenoid and see if you can lubricate it somehow. Silicon spray good for these type of problems. Squirt some inside the boot on the push rod.
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Hopefully will have this sorted later today. Off to Tonys in a bit.
Grumps
Z4 e85 2.5i
Thanks to @t-tony my boot now closes and mores the point stays shut!!! As a lot of you that have followed me will know it has a tendancy of popping open, hopefully now it won't. The maiden voyage home went to plan so fingers crossed.
Grumps
Z4 e85 2.5i
Nice one Grumpy, by the way did you go through Banbury on Thursday in your truck as a saw one with name plates for the driver Grumpy and side kick Barry I weren't quick enough with the phone to get a shot but did make me chuckle and think of you.
No mate I've been away. Back to work Monday. Haven't got a name tag in my window but quite fancy one. :)
Grumps
Z4 e85 2.5i
Does it begin with T? @t-tony Just done a run to a friend's for tea and one of the roads is rough as a badgers and the boot stayed shut! :D
billz
Langley Mill
Lets hope thats the last of it Dave. I know it has been doing your nut in.
Was it just a case of adjustment ?
Grumps
Z4 e85 2.5i
Yes mate. Tony thought it had been to tight on the rod. Backed it off, moved the plate and catch a bit and bingo. Been out tonight and it's been spot on.
Grumps
Z4 e85 2.5i
Just driven home in the dark with the roof and windows down and it was lovely. Shame we don't get a bit more weather like this.
Did that 3 years ago, probably this weekend Dave as it was after a birthday party for our Abz who you met this afternoon, drove home from there's in my Z3 and when I got home my bloody hair was ALIVE. But yes it's great driving top down after dark and this time of year you get the smell of flowers and stuff you would miss in a tin top mate.:thumbsup:
Grumps
Z4 e85 2.5i
Absolutely mate. Mints told us to try it last year after we left them after dark. It's quite a surreal feeling but very nice when it's warm enough to allow.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Top down driving after dark is the absolute best! Takes me back to my youth cruising in a 62 Implala convertible with a hot little lady beside me. If you don't do it you don't know what you are missing!! JIM
Any chance you could send me a "hot little lady" Jim, but for Christ's sake don't tell Shirl!=))=))=))
Grumps
Z4 e85 2.5i
I'll have the 62 implala!
Bonzeau
Aylsham, Norfolk
Z3 2.8 litre Roadster
What's an implala?.................I'd sooner have an Impala! :rolleyes: (Chevrolet type)
:drinks:
Bonzo.
oldcarman
Canadian Zeds
@ t-tony would gladly send you one but would your ticker take the strain of one from the sixties or would I have to worry about her??
@ Grumpy, don't have a 62 impala but do have a 61 Pontiac Parisienne convert that needs some finish work. I have most of the parts plus a new interior and hoods in white or black!! Let me know and I'll arrange shipment to the nearest port!! Google a pic, because they are pretty wide bodied!!
Oh yeah, so are some of the ladies for Tony!!
