How to unlatch passenger side bonnet latch when the cable is broken or untethered
For clarity. If you’re sat in the car this is the left hand side latch.
It is the latch which sits next to the manual, secondary bonnet release.
You will need:
Trouser belt
Bore camera (Depstech DS520)
Tent peg
Adjustable pliers
Cable ties
Feed the trouser belt through the slats of the kidney grill. Put the belt under tension and give sharp tugs until it releases.
Feed the bore camera through, as per these pictures, so you can see the latch mechanism.
Secure the camera cables in place with atleast 3 cable ties and be careful not to move it.
Feed a tent peg through the small hole. It’s very tricky and you just need to feel your way through this.
I bent the end of the tent peg to more about an 80 degree angle
The end also has a 2-3mm section slightly filed to give a flat but rough surface for a better grip.
(I didn’t file it, it was pure luck and coincidence)
Don’t try and get the peg in the hole. I just caught the back of the latch and gently pulled using my left hand.
My right hand was pushing up on the peg to make sure it stayed seated.
When I needed more grip and leverage I used the pliers to grip and pull on the tent peg all while maintaining pressure and stability with the right hand.
When the bonnet pops don’t let go of the pliers or peg!
Maintain pressure with the left hand and use your right hand to lift / jimmy the bonnet as it may snag slightly.
Once you’re happy don’t let go of the bonnet in case it latches back shut under its own weight.
Job Done.
I would say the bore camera was essential for this. They’re relatively inexpensive on amazon.
I’d recommend one with an LED light.
If anyone else does this, good luck to you.
And thank you to everyone for helping me with ideas and guidance.
All the best
