Thank you for letting me join this forum.
I have a 2014 BMW Z4 with the roof stuck in the closed position. Does anyone know of a roof specialist in the Edinburgh area as, like another member said, I'm reluctant to take it to BMW. The roof issue is probably a result of water ingress as I had to drain about 4 inches of water from the boot. I've tried replacing the roof motor and a couple of relay switches which were sitting in the wet area but this has not solved the problem. From what I have read I believe it is likely to be a "micro switch" somewhere but I will need a specialist to confirm locate and hopefully replace it or them.
Also, does anyone know if there is a typical route for the water getting into the boot? Any suggestions please?
Feeling doom and gloom as I've seen posts on another forum saying BMW want to replace whole
roof and I shudder to even think how much that would cost.
Thank you in advance for any thoughts!
