So my dear friends , 1, do I add spacers? 2, if so what mm should I go for? and 3, fixed stud or universal?
Thanks for reading!
Cheers
Dave
Gaz, there's 18's and 8.5j but I don't know the offset. I was thinking 15mm to bring in line but didn't want to go to big and them stick out like a tractor!Yes I think you need to fill those arches a little more.
You want 5x120 pcd hub centric spacers. The width you need depends on your rim size, and how much you want to fill the arches.
On my 8.5x18 rims with et40 offset I needed 15mm spacers which brought them perfectly in line with the arches. Be interested to see what prices you come up with because I want to buy some more soon.
Super, thanks very much. Just how I like things. A nice simple explanation!Offer a piece of wood vertical from edge of wheel arch to ground, then measure horizontal gap between middle of tyre wall and inner edge of wood. This will give approximate size of spacer required.
Hi Dave, as you know I've just fitted 8.5" 18's.It's 20mm so I need 5x120pcdx20mm?
Thanks Tony. Looked up the hub centric ones. Not cheap are they! But it's like Lex says, they need to be of a good quality. I'll search hard and hopefully knock a few quid off!Dave, I put some on mine last year which I brought home from the US. If you check out the write up its on here.
That's by far the best price I've come across Dave. Please can you give me the details?will be going down this route myself very soon, am thinking a 20mm spacer for the back and 15 for the front, look forward to seeing your results Dave
ive been looking at options and seen a guy selling 5X120 20mm with studs and are hubcentric for 65 euro here, this seems to be the best price i can find bar finding a second hand set, which seem to be non existent....
Brilliant thanks Davehttp://cars.donedeal.ie/alloyswheels-for-sale/wheel-spacers/5748839?offset=11
page to seller, they look like great quality also Dave so i hope this will help you ;-)
Looks good TonyHi Dave, I had 20mm on the rear end and 12mm on the front and they fit the arches spot on. View attachment 13842 View attachment 13843
