Hi FrankieMark, I've read what Jim has written and I was confused about him saying that a DMF ( dual mass flywheel) can't be skimmed. It was at this point that I had to research the DMF as I had never replaced one. I started with the u-tube hyperlink Jim provided. I noticed that they are used for diesels to dampen vibration, but are also used for passenger cars. This video seems to indicate some problems inherent with them. The grinding of the flywheel I was referring to is only done with single mass flywheels. When this is done, an extremely small amount of material is removed. Usually about 20 thousands of an inch. I called a shop that specializes in flywheel resurfacing and they highly recommend the procedure. This procedure removes hot spots caused be excessive heat and any unevenness that can cause clutch chatter. To be fair, this can cause the new clutch to fail sooner but only an extremely small amount and cannot compare to the resulting smooth clean operation the new clutch is able to achieve against a clean even surface. This is a video of a clutch surface being reconditioned:
http://www.youtube.com/watch?v=f7AjwdIWh4c&feature=player_embedded
A good video of what a DMF is:
http://www.youtube.com/watch?feature=player_detailpage&v=MfNjARZc5Wo
The video that Jim provided gave me some second thought about these units as evidenced by this video:
http://www.youtube.com/watch?feature=player_embedded&v=DHapjYefAt4
In my first post to you, I talked about replacing the clutch and the parts involved. This may have been like Greek to you but the following video shows what a lot of the parts that I referred to are. Take special notice of the pilot bearing, throw out bearing and the clutch disk pilot tool I was referring to. It helps if you move ahead during the video to skip removing the exhaust and other parts of the video that don't apply to the clutch.Frankie
http://www.youtube.com/watch?feature=player_embedded&v=kaM8RgUWmKM
Your very kind for sharing that with me
I enjoyed the u tube links and feel I learned something from your post .
Thank you so much for your help
M
for all your help
