just checking my car to try and find why it only blows hot air, it is a aircon model not working. the car is a 1.9 8v according to some reviews i read the heater valve may stick causing it to blow hot air all the time, on checking there is no heater valve i have the bracket were it should be and the power plug, but there does not seem like it as had one fitted all hoses seem to go to the correct place, my question is because it as air con did it do away with the heater valve, if so were do i need to look for other problems,
