Anyone have any tips on best way to get 12V into z3 door?
I don't fancy tapping in to anything powered by the ZKE so haven't even checked to see if there's a permanent 12v already in there - unless somebody has done it already and says it worked OK.
I'll be dumping the door speakers so maybe I could cut the speaker wires under the dash and move them over to use as my 12v supply? Or maybe the heated mirror wires? maybe from the fag lighter?
Just thinking that using some unused wires in the door would be easier than fiddling new wires through the door grommet?
Is the door panel properly earthed?
Suggestions anyone
Suggestions anyone
