So today we tackled lots of little jobs while we wait for the powder coated bits to return and the clutch to arrive.
First job was to remove the old diff bush and give the diff a coat of hammered black paint finished off with a powerflex bush.
Next we moved onto the main reason why Bella has made it to us, the gearbox shift pins. The first pin I fitted were the 1-4th gears. First photo shows the 3 caps to remove.
Old pin (larger) next to new pin
new bush installed and pin with new spring dropped in.
and then fit the new cap
moving onto the next shift pin, my tool of choice for removing the old pins, it’s actually older than me...
These 3 shift pins take minutes to do so no sweat doing these.
The more difficult pins are 5th and reverse. Both have some areas you really need to pay attention to.
Reverse being the top shift pin and 5th the lower they both have a rotation to watch and both have slightly different angles on the pin. Reverse has a straight edge while the 5th gear is curved, very subtle but you can tell the difference.
reverse done at this stage and I just finished breaking out the old liner. It’s this liner that grabs the shift pin causing it to stick and lean.
New liner in and spring.
Full house of extracted old pins. Note the two larger pins, hard to tell they’re actually different in the picture.
finito
Moving onto another really satisfying job, the fuel tank straps, such a nice design. Old straps very much past it.
Whilst the gearbox is waiting for new seals and oil I removed the selector seal, this is causing the rear of the box to get very wet. Very common at this age.
We also gave the under side some serious elbow grease and a nice coating of treatment and rust prevention. Also nice to see the new tank straps in shot.
Rust treatment product
wide angle lens
Normal lens
We got the call late today saying the powder coated parts are ready for collection tomorrow.
Watch this space
