Been Spending (what treats have you got lately)
Sean you've done a top job there :scorecard:
Better get them bolted in quick before Steve @Low Rider wants them back :D:D
He is welcome to them mate....................................................................................for the right money of course :D
Reckon with the work you've put in sean and the finish you have achieved you must have at least doubled their value :whistle:
I couldn't afford them now after your hard work Sean. Can't wait to see them bolted in
Thanks for the kind words guys, I am rather pleased with them, there is a couple of niggley bits on them but overall they are better then I hoped for.
Cant wait to fit these, then @Lee we'll have another go at that corner :eek:
Cool, you got them all eventually... If I remember rightly you got them from Euro parts? Did they do you a good deal? This is the complete suspension kit/set up?
Eventually! just high performance shocks, got just under £90 off for my troubles ;)
Just purchased some
Crystal Serum Light + EXO Kit and some C4 Permanent Trim Restorer. Will be using it in the spring when its time to machine polish the zed again
Cleaning stuff... I can see the results on the trim but what is the serum? Sounds really high tech... It's a big industry isn't it.. before I bought my z3 I had no idea how specialist car washing had become.
I've just learnt what claying is :)
The Serum is a Ceramic Coating that goes on the car applied directly to the paint this helps to protect the paint. The Exo kit is a top coat that also helps protect the paint and also helps with the shine. When done it should last a couple of years. Just need to then wash & dry weekly and wax every 3 months
http://www.cleanyourcar.co.uk/washing-and-drying/gtechniq-exo-and-crystal-serum-light/prod_1636.html
This stuff had better be good for £20. I knew it was 30ml but forgot how little 30ml was.
It is for the external Trim. I should presume a little goes a long way. I have found though a lot of stuff is expensive it lasts a long time and equates to a small cost per application. The Wax i use is £40 for 50ml pot but will do around 8 to 10 coats which will last around 2 to 3 years so it equals to around £4 per application and less than £20 per year
