Hi all,
Really surprised i have to write this.
Just started fitting my bc racing front coilover suspension and it doesn't fit.
The holes do not align on the wheelhub.
I first fitted the top screw, then the 2 bottom screws, but i could tighten then up.
The hub surface is not flat to the plate on the coilover.
I tried a different hub (i have a spare set) same issue.
...and it's on both sides.
To make sure i'm not mistaken, i took the other way round in fitting them.
First fitting the bottom 2 screws, so for sure both surfaces are now sitting flat, the top bolt is not aligning at all....
...look at the picture with the bottom bolt fixed....
Paying a 1200€ for a set of coilover then getting this quality of alignment???
@Lee @Brian H @Dino D
Did you have the same issue? I can't imagine the fixing would be ok.
And putting more pressure on the bolt it would snap.
Regards, Koen
Regards, Koen
