Anyone know what the torque settings are for BBS style 42 rims, I think the 108s are around the 18 ftlbs mark,
Cheers
Cheers
Thanks for that pal, I emailed Bbs and asked if they could supply me with a drum only, I got a real shitty email back off them stating that if a wheel had been split it was no longer road worthy and that's why they will not reveal any technical specHere you go. Can't see why these would be any different to 108s if the bolt size is the same.
https://zroadster.org/threads/bolt-torque.21515/
I guess you both were talking at cross purposes Sean. It can be difficult talking to Americans because their English is not the same as ours. It only takes a small thing for there to be huge difference in implication. I had no issue getting the relevant info, if you told them that you had a cracked rim then they would go into CYA mode.Thanks for that pal, I emailed Bbs and asked if they could supply me with a drum only, I got a real shitty email back off them stating that if a wheel had been split it was no longer road worthy and that's why they will not reveal any technical spec
