Battery
AntStark
Hampshire
2002 3.0 Sport
You can use AGM or conventional. Most manufacturers and larger online retailers have a search function for you to find the right one for your particular engine size
Maybole , South Ayrshire
Agreed not required for a Z3
AGM battery was designed primarily to be used with stop start systems to help with the extra abuse played on the battery with the exra starts but on a lot of these equipped vehicles the battery is part of a system which can include battery monitor systems, variable rate or high charge alternator that can run sometimes over 15v so these types of car need correct type of battery wgen replaced or problems will soon return .
Stephen.
SV8Predator
Z4 E89 2.0 Atacama Yellow / Z3 3.0 Topaz Blue
Do I need to use a AGM battery in my 2001 Z3 ?
You don't "need" an AGM, but it can be a good idea if you don't use your car regularly. The AGM will hold its charge for much longer.
