Battery…
Neilb62
Darwen
3.0 Roadster.
Hi all.
Need a new Battery for my 3.0.
Leaning towards Bosch but what’s good otherwise?
Ta.
Neil.
Yuasa, Exide.
AntStark
Hampshire
2002 3.0 Sport
I got a Bosch for my 3.0l .. but also as Tony said.. just make sure it’s got enough umph!
2.2 & 3.0 Sport
Bosch all day long for me:thumbsup: got one for the 2.2 back in July. The last one only lasted 11 years :whistle:
B21
Scottish Borders
E89 35is
Varta, Yuasa, Exide
All OE suppliers..Exide to BMW for sure
Other folks on other forums have made negative comments on Bosch but I've not personally seen any issues.
My Z4 runs an AGM varta and our Volvo XC70 had Varta as OE.
Mike Fishwick
French Zeds
Daglan, France
German batteries are tested to DIN standards, where they have to pass the cold cranking amps (CCA) for a minute - oriental types are tested to the SAE standard, which calls for 30 seconds. This means that the German battery is a lot better than an oriental type, regardless of the name on it.
Bosch, Varta, or Sonnenshien are all good. Use of a trickle charger /automatic charger will extend battery life a lot - I usually get 10 to 12 years from a battery.
B21
Scottish Borders
E89 35is
DIN was replaced by ETN in 2006 onwards which is a superset of the relevant DIN standards.
Oriental appears to be a somewhat derogatory term for a multitude of countries, each with different quality standards for products at differing price points.
Yuasa batteries for the Z4 E89 comply with EN1 as part of ETN..
Because of confusion between ETN! and ETN2 SAE is often used as its simpler to understand.
However you look at it Yuasa AGM batteries are the equal to VARTA and others..I bought Varta on price and availablity.
If Yuasa was price competative then I would certainlly buy them.
E89 data sheet here for completeness
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
It's smarter to fit Varta! I'm sure I heard that somewhere. :p
Andyboy
SHEFFIELD
I buy all my batteries from BMW.
Most dealers will price match if you ask nicely. My last one (80a iirc) was £88 with VAT.
It's nice to open the bonnet/boot and see a BMW battery.
The first one I bought was in 2007 for my 7 Series and it's still good.
Buy cheap, buy twice.
Andyboy
SHEFFIELD
Okay…….:rolleyes:
What brand are they. It'll be on the battery somewhere.
Tony
