NopeAre all z3 anti roll bar bushes the same size
Lots of variation
Didn't drive it as it looked so bad.Have you tried removing the rear spring pads. I believe it’s something like 1.6 ratio so taking out a 10mm pad gives 16mm drop.
How did it drive with that set up?
They vary between engine sizes and spec.Are all z3 anti roll bar bushes the same size
Glad you liked it .Just read through this entire thread. Great work and very inspirational, Sharp3y.
Be interested to hear the outcome, I did the same but ended up with no speakers so had to reverse back.Another small update.
@spurs fan in a coupe kindly sold me some new boot carpets so I could remove my hump.
Small issue that I had to remove the HK amp as it doesn’t fit behind the carpet nicely. I’ll do some research to see what I can do as I now only have front speakers.
Anyone else done this with the HK setup?
Loads more boot space though so I’m overall very happy
Got myself a genuine bmw first aid kit for £5 to finish off the boot for now.
Next job is a big front end overhaul.
I’ve got brand new wishbones, steering rack ends, gaiters to go on
Along with 300mm front brakes from a e46
All that’s needed for the brakes is the carriers from the donor car which I picked up for £20
They are currently soaking in a bath of citric acid to remove the rust
Also ordered some front HEL braided hoses and will be buying some brand new (refurbed callipers)
Looks like the previous owner has bypassed the amp and wired the front speakers up to the Headunit. I'm tempted to do the same for the whole lot or see if I can come up with somethingBe interested to hear the outcome, I did the same but ended up with no speakers so had to reverse back.
Mine was I'm the hump above the cd changerIs your amp in the hump ? mine is not it was just empty it mounted on the drivers side rear on the arch behind the carpet.
Mine used to be there too.Mine was I'm the hump above the cd changer
That’s a neat spot...mmmm time to get rid of my hump too it seems!Is your amp in the hump ? mine is not it was just empty it mounted on the drivers side rear on the arch behind the carpet.
they have come up much nicer than i expected, going to paint them with some caliper paint next and then fit them up at the weekend.Looks like they came up well after a soak
