removing the seats is not a problem at all David, you would do it in 5 mins, take them out and have a look at a few things if nothing else, maybe you could throw about some grease and WD40 for sport ;-)
Where did you get your replacement switch from?same problem seat would go back but not forward or up and down, changed the switch it now goes back and forward, but not up or down, no noise from the motor when operated up or down but it is in the right position for me so not a problem, but would be interested if some one finds out a good fix
Yes still available but the white connector is attached to the actual switch, so in my case would have to buy the complete switch at a cost of £165 , think I will put up with using the seat asit is for the momentThis page shows the seat switches & part numbers. Not sure if they are still available now or not, but give @Soper Parts Lincoln a quick call and they will tell you!
http://bmwfans.info/parts-catalog/Z...cle_electrical_system/switch_seat_adjustment/
