Alarm Sounder / Klaxon Tamperproof Nut Removal - Solved
MikeP
West Sussex
Hi,
Does anyone have ideas for removing the tamperproof nut on the alarm sounder?
Mine is mounted on a bracket under the fusebox and the bracket is folded in a U preventing access from the side
You'll need to cut the nut off if you want to reuse the stud or bolt. It all depends on your intensions for it's removal.
So, after much cursing I finally found a way to undo this nut without causing any damage (except to the nut) .......
BMW helpfully left a small rectangular cut-out in the side of the mounting bracket and by inserting a sharp, flat head screwdriver through this slot I was able to dig the corner of the blade into the nut then, using the cut-out as a fulcrum, lever it round.
Hopefully this might help someone else save a few grazed knuckles :)
