Airbag light
Sean d
Lincolnshire
Guys, does the airbag light cover any other faults as I was doing some spirited driving today and went around a left hander a bit sharpish, the ACS kicked in and I looked at the dash to see if it had lit up (for some strange reason I always do this) at that point the airbag light flashed and then came on, I need to get a code reader on it.
Dino D
Kent
2.8 Manual
Serious gforces have caused a loose plug?
Must be some pretty seriously gforce though!!
Maybole , South Ayrshire
Only the bags and Seatbelt pretensioners Sean get it plugged in see whats up.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
if the battery is not securely clamped down it can cause issues
Yep, there is a connector on the battery clamp that serves the airbag system, worth a look.
Mani
Z3 2.0i
Worth checking the wiring under the passenger seat, with the heat it could have been some lake that's let go etc...
Sean d
Lincolnshire
Now thats interesting, its also occurred to me that my daughter raised the passenger seat to its limit shortly before.
