Airbag Light
Hi moved my passenger seat backwards the other day, probably the first time its been moved since I got the car and now I have the air bag light on the dash :mad:
Any ideas?
Thanks in advance
Niall
Low Rider
I'm not sure but may be a poor connection on the plug under neath the seat.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
You might have loosened the underseat wires. It happened on mine too. You'll need to clear the code and reset it
littlefeller
evesham
yep, common chain of events=)) when i brought mine it looked as though the seat runners had driven over the cable (this was a common issue on the zed from new)
though i will second the plug check, they do come loose by them selves.
if you need airbag reset, let me know maybe another meet is in order:)
Jack Ratt
TRURO, CORNWALL
Jack Ratt
TRURO, CORNWALL
Mine works for my pre face lift and on Adrian's face lift zed.
Steve
My car is pre facelift and Lee's kit couldn't communicate with my car and neither would Paul's when my airbag light came on during the Euro trip. When I got back I bought my own on Ebay. The seller said the facelift and pre facelift setters are different.
It's good to know that it is not the case across the board :thumbsup:
Faheem
Leicester
I have one of these reset tools as well and the number of times that I use it is unbelievable.
My Zed does the same thing, if I move the drivers seat too far forward then the airbag light has a tendency to turn on, I've even replaced the yellow cable that come attached to the seat hoping that would resolve the issue. It's an intermittent issue but since I used electrical cleaner on the connectors it doesn't come on as often.
N
N4LLY
Guest
Mine has also started coming on, but only when someone is sitting in the passenger seat.
Just be out to double check, start motor from drivers seat and hopped to the passenger side and the
airbag light came on.
Had a look, could not spot this yellow cable passenger side ?
Thanks all, looks like I need to check the cables then get my mate to do a reset, if his wont work (snap-on unit) then @littlefeller may be arranging a meet :thumbsup:
mid life crisis
Worcester
2.8 Z3
Take the seat out, clean up the connection plugs with a drop of WD40 Including the one on the seat belt tensioner.
I've got a reset tool when you need it
Regards
Gary
