Airbag light on the cluster
twtgs7
Z3M roadster,airbag light working on the cluster....
Wires under seats are ok...
What else is maybe problem?
You need to get the fault codes read to see what the issue is otherwise you just end u pgoing round in circles.
Stephen.
As @Stevo7682 says, code read it with a scanner for airbag codes then post results on here for advice.
