Am I not supposed to do it to get rid of remainder of charge anywhere?You don't need the ignition on at any point when the sests disconnected its what triggers the light.
What @lazzydog says!Thanks Lazzzydog appreciate the tips I'll have a look on eBay for the gizmo thing that way I can make sure it is the pad if it is I'll replace it. Yep I have enjoyed the 350 miles I've done since I've owned the car not much for a year but I don't seem to get the time. Don't think I would sell but if I do I'll let you know. Thanks again.
I’ve done the aerial on mine. What year is yours? I got sent the wrong on (pre2000) first so have it spare somewhere. For it, you need to loosen the hydraulic pump for the roof and a couple of nuts. Try to lube it up first so it pops off. Same with putting the new one on.Can anyone help my airbag light is on I have a scanner and it came up code18 seat occupancy detector passenger I had my mechanic have a look he took the seat out wiring seemed ok although we had some rodent problems! Which must have been before me. Also the carpet behind the passenger seat had water underneath but I never take my car out in the rain and I've had it a year. The arial washer is split and the roof is not good. I wanted to drive to Spain next year but so much to do seat bushes, airbag, leaks, service, water pump! Anyone want to buy a 60k 2.8. Any thoughts will be much appreciated
