Danzzzz
- Joined
- Sep 25, 2017
- Points
- 16
- Model of Z
- z4 2.5i
A common theme but I couldn’t find a thread with the same fail codes
I’ve periodically had the yellow handbrake and traction control light come on.
It’s gone off on its own eventually but I bought a c110 scanner to see if I could work out what the issue is.
So I get codes 5DF4, 5E19, 5E20 and 5E21
These point to both pressure sensors, which would seem strange that both are faulty, pointing to the dsc unit itself? But I thought if it were the dsc unit itself, the lights wouldn’t go off again?
So I changed both sensors today, hoping I might get lucky but the codes are still there although no lights on the dash!?
Before I look at a refurbed unit, would it be worth changing the wheel speed sensors or is it looking more likely to be the abs pump unit?
Any advice welcomed
Any advice welcomed
