Hi all,
With all leaks sorted thought I would take the Z3 out in the sun this morning. Give it a run and take the wife shopping. Couldn’t believe it when the car suddenly over revved and wouldn’t shut down. I turned off the engine, put it in neutral and coasted to a halt. I started the engine and it was still wide open, so turned it off and got under the bonnet ( or hood as they say in far off places!).
Fortunately there was a screwdriver in the boot kit so took off the plastic cover over the throttle linkage and flicked the spring back and forward a couple of times. It was covered in that white paste ( marine grease?)
but couldn’t see anything actually wrong. Started it again......and lo and behold back to normal!!
Has anyone come across this before where it just sticks open????
Any way, carried on and went shopping and did a round my trip of about 30 miles or so and it seemed to be ok other than the idle speed varied at times.
Got home took the cover off, released the cable and squirted wd40 down the cable. Cleaned the springs, (decreased and oiled them), and sprayed the pedal connections, bushes and spring with wd40 as well. Testing it in the garage it appears to be all ok now.
I can’t really see why this should have happened though.
Anyone have any ideas?
