ABS/ASC lights on
Thanks for that - I found it myself and just read through it, very interesting - looks like the Stanley knife/soldering iron option for me - be nice to find the dry joints - although should really go for the sensors check option first. I've got the BM cables software but never managed to get it going. I've got the C110 which is a bit basic and the Delphi diagnostic tool, but it looks like the INPA is the one to use.
It's just the ASC switch that makes me wonder if that is faulty - ****ing cars
The switch is just an on/off switch it should be easy enough to rule out ?
what computer are you using for inpa? if you can get it working it is more usable, the bm cables software does come with the expert software for coding. opening the module should be the last option, i cant see why it would fail if it was fine when you parked it up. have another bash at getting inpa working.
me and ant both has the same problem but diagnostics threw two different codes, mine was something like pump valve wiring harness, it also threw a code for one of the wheel sensors but i never needed to check those. another common fail area is the coils found on the back of the module, they are the round rubber things you can see in ant pic, the coils are encased in rubber but looking through other beemer forums when i had my problem these to can fail, the wires inside the rubber can break. if these go inpa would show a different code, this is why you really need the software working to narrow it down.
The other code was relating to electro magnetic interference if i remember it relates to front left sensor but it never cleared on replacing the sensor.
Again not sure if that was a bad joint too relating to the eletro magnet in the module.
The module removed them all..
Have you taken the car out for a run ?
The abs light unlike others will extingush its self.
Prior to me changing the module the light was on and off for a while. It resets under self test at ignition may be worth taking it out for a good run and settling it.
Also is the battery good after its hibernation ? Sometimes a poor 12v signal causes spurious codes in these little cars
just noticed error code 93, this is specific code relating to the abs on cars that inpa recognises as mk20, same as mine - a 1.9 is your zed a 1.9? on different zeds the code would be different.
11 Front left wheel-speed signal
12 Front left wheel-speed signal
14 Front left wheel-speed signal
15 Front left wheel-speed signal or front left outlet valve
21 Front right wheel-speed signal
22 Front right wheel-speed signal
24 Front right wheel-speed signal
25 Front right wheel-speed signal or front right outlet valve
31 Rear left wheel-speed signal
32 Rear left wheel-speed signal
34 Rear left wheel-speed signal
35 Rear left wheel-speed signal or rear axle outlet valve
41 Rear right wheel-speed signal
42 Rear right wheel-speed signal
44 Rear right wheel-speed signal
45 Rear right wheel speed signal or rear axle outlet valve
61 Front left inlet valve
52 Front right inlet valve
53 Rear left inlet valve
S4 Rear right inlet valve
55 Front left outlet valve
56 Front right outlet valve
57 Rear left outlet valve
58 Rear right outlet valve
61 ASC special valve
71 Pump Motor
73 ABS control unit
76 Electromagnetic or mechanical influence of wheel speed signal
78 Battery voltage
81 ABS/ASC main relay
82 Solenoid valves power supply
83 Solenoid valves power input
85 Solenoid valve coil
91 CAN: chip in ABS/ASC control unit
92 CAN: bus faulty
93 CAN: engine intervention
94 CAN: engine speed
95 CAN: connection failed with DME/DDE
96 CAN: connection failed with EGS
97 Incorrect coding
98 ASC button
engine intervention is some kind of communication error.
Using an old Dell computer running Windows 10 Home version 64bit - did have an half hearted attempt to load the software when I first bought it and found the program a bit confusing and half of it in German - so reverted back to my C110, and the BM cables setup got thrown in the cupboard with the rest of the useful stuff I have bought and never used - will get it out later and try and get it set up. Might get a bit more specific indication of what's up. Going to get the sensors out today (hopefully) and give them all a clean.
Thanks again for that- I haven't taken it for a run - it's still on Sorn so I daren't go too far in it at the moment and reluctant to unsorn it, tax and insure, if I can't use it - but will have to do so in order to sort out this problem. I have a 4x4 I run during the winter while the Z is off road and then swap them over during the summer months. Appreciate it needs a good run and then looking at again.
The battery was new last year and has been kept on a trickle charge over winter - car always starts first time so pretty confident the battery ok. Alternator putting out 14.1 volt when loaded!
71 Pump Motor
73 ABS control unit
78 Battery voltage
92 CAN: bus faulty
97 Incorrect coding
98 ASC button
Thanks Mate, Yea it is a 1.9 - are the codes you list specific BMW codes - with just having two numbers I would have thought the codes would be something like P00** or similar
