Since changing the rear dampers, top mounts, ARB bushes and drop links recently I have a rattle/noise. Not the same as you recorded but just as irritating. Like yours it is not present with the roof down (or at least I cannot hear it).
A week or so after the new dampers and top mounts were fitted I checked the fixing bolt on the damper shaft and found that the reinforcement washer had very slight movement, I tightened it maybe an eighth of a turn and it was solid. This seemed to cure it for a couple of days, then it came back. I presume that the top mounts had settled very slightly allowing the washer to move.
The new bushes and drop links were fitted with a bush lube but there is a bit of a creak on the drivers side. It seems that the new parts have changed the dynamics of the rear suspension and bought out problem that was being masked by the old set up.
Today, in addition to checking handbrake cables etc, we applied some bush lube to the bushes that were not replaced (not sure if it will penetrate at all) and to the spring pads in the latest attempt to get rid of the offending noise. Unfortunately it was raining and the effectiveness of these measures will have to wait until another day.
Keep us all informed as your investigation progresses as it seems you are not the only one with this type of concern. Good luck.
