Silent running
- Joined
- May 5, 2020
- Points
- 4
Hi all,
Always had BMWs as main car and recently alongside this, an MX5 for the summer for a bit of fun. But now they're all so rotten, it's not even worth paying three figures for one. Hence this summer's daily/project is an S reg 1.9 MOT failure that needs a bit of suspension work basically, picking it up next week. Only annoying thing is the American Haynes I've bought doesn't show the spanner rating! Jobs will include:
- replacing front wishbones/drop links (MOT failure, easy fix and cheap)
- maybe replacing o/s/r trailing arm - need to get it up in the air to have a look at how rotten it is (MOT failure)
- maybe clutch (get mechanic mate to do!)
- a few niggly electrics (easy)
While I'm under there refreshing the suspension, assuming the struts are OK (we'll see) I might well change the rear ARB. Before anyone chips in with advice, it's just something I always tend to do with rwd/awd cars. All I really need to know is, are all Z3 roadster ARBs the same width i.e. left to right, not thickness. Will they bolt in at the same place, as I want to stick a 2.2 rear ARB onto a 1.9. I'm sure someone will correct me but the 1.9's the thinnest, then you've got the 2.0-3.0 ones, then the M. Does the wide body of the later Z3s make any difference to where the ARB locates, in other words.
And where can I source a cheap trailing arm if I need one? Front control arms seem cheap as chips on eBay, but rears are almost impossible to find except from breakers.
Cheers!
Nick
Cheers!
Nick
