All good, confirmed the miles and turns etc. Found a better photo stop too. 1hr 40mins inc. a 10 minute photo stop.
Good work Tony, with all this research it should run like a Swiss watch on the day .All good, confirmed the miles and turns etc. Found a better photo stop too. 1hr 40mins inc. a 10 minute photo stop.
It's a free download and allows you to construct a route of you're own, which you then upload to your satnav.What's this tyre app?
Might try and transfer it via tyre/nav and see how it does on the recce.Shirl is hoping to type up the route tomorrow and then I'll post it on the PM Steve.
I'd agree Steve, the best way to cure that problem is to put in plenty of way points. The more there are the less chance that Tom will link up two way points differently to TYRE....but maybe that's down to who ever plotted the route and way points
Thanks mate,I reviewed how I plotted the route in tyre and I had enough way points but I hadn't zoomed in enough to notice exactly where some of them were.I'd agree Steve, the best way to cure that problem is to put in plenty of way points. The more there are the less chance that Tom will link up two way points differently to TYRE.
Good to see it (mostly) worked...AND you were in our neck of the woods. Good job you didn't call in ....we were on holiday
Ha, yes I've have that problem. It's worse when the way point is on the other side of the motorwayOn closer inspection I could see some of the points had landed slightly off the intended route...
So easy done .Ha, yes I've have that problem. It's worse when the way point is on the other side of the motorway
I'm sure it'll be fineHaven't trial run it yet though,so an excuse for a drive one weekend .
