Personally I think it's a case of " If you can't see it, it doesn't matter" And, you can't see it until you open the hood or the trunk !!. Never seen it on a European BMW only the US models.
I never thought of it as heat protection but interesting you mention it, not had an issue and have it out for a few years now though.Removed it today and cleaned it , it wants replacing really but will leave it on rather than risk any heat damage to the bonnet .
just need a bit of carbon to finish off that radiatorView attachment 34537
Happy with the results the power steering cooler certainly looks better but wants removing really for full clean and power coat but crustyness has gone and it looks a little more respectable.![]()
No sorry, not at the pod this weekend.Not sure it will fit to be honest the rads fairly new and it measures short of 40 mm. Are you at Santa Pod sunday ?
Looks bob on mate, the inside of my doors are a tad manky, I'll bring it roundBeen waiting on a set of sill guards to arrive from the states all the uk ones i have seen have been badly corroded due to our roads and salt.
Looked all over but found a set on ebay.com
There not perfect but 100 times better than what i had and for under half the cost of new im pleased.
Whilst fitting them gave the door openings a good clean not been done before but now spotless.
And after all these shiny engine bays of late decided i must get mine respectable.
Gave the power steering pipe a sanding and a lick of paint and degreased and cleaned it up.
Can you tell im looking for things to clean ..Next op on tuesday and then back to sofa surfing.Looks bob on mate, the inside of my doors are a tad manky, I'll bring it round![]()
They say anythings possibleCan you make it over here and back before next Tuesday?? JIM
Every little helps mate. Good luck with the Op and a speedy recovery. Oh, your bonnet catch could do with a clean and when you've finished, so does mine mateCan you tell im looking for things to clean ..Next op on tuesday and then back to sofa surfing.
There only so many episodes of wheeler dealers one can watch![]()
Already got them coveredEvery little helps mate. Good luck with the Op and a speedy recovery. Oh, your bonnet catch could do with a clean and when you've finished, so does mine mate![]()
No such thing.Far too much tinkering time![]()
I'd be happy to mate, whenever. I've got two trolley and some small stands so we could get all four corners up and level.Not quite the same satisfaction in that hey @t-tony
You may be able to assist me in a few weeks with a full fluid change i could do it but i'll struggle getting it high enough off the ground...
That's pukka mate, mine needs a bit of TLC.
Sounds interesting ! I'll finish geting all the fluids together that i'll need and then will sort something with you. Appreciate thatI'd be happy to mate, whenever. I've got two trolley and some small stands so we could get all four corners up and level.
ps. New small project starts this weekend, if they arrive on time.
Always thought them a little shabby and when @Low Rider did his it spurred ne on to get them sorted.That's pukka mate, mine needs a bit of TLC.
