A/C check
Braz86
Aylesbury, Bucks
Has anyone linked out their A/C clutch at the relay or somewhere to test for functionality? I've got a DIY filling kit which I've used on my daily, but need to try and pull the clutch in on the Zed to top it up as it is probably too low for auto engaging
FRANKIE
I'm not quite sure what you're saying. I do know that if the amount of gas is too low, the clutch won't engage. Once you fill it, when it hits sufficient pressure the electric clutch kicks in. There are ways to electrify the electric clutch to see if it is operating. If its not working, there is sometimes a thermal cut off switch often located on the body of the compressor that is in line with the hot wire that can go bad and must be by-passed if you're not sure it's defective. I believe there is a pressure sensor switch also. Perhaps @t-tony can shed more light on this..............Frankie
Mario
You are better off bridging the pressure switch that is in the drier just unplug the connector and bridge it
