Nice one @ t-tony!! Hope you get to the bottom of this and it's not too serious!! JIM
Hi, so if the car isn't over heating why are you concerned. If it had a head gasket or head problems you would have oil in the water, water in the oil & the cooling system being over presurized and lots of steam out of the exhaust.
There are many owners of 6 cylinder Z3's that have changed the thermostat/ water pump. All these cars are over 15 years old now and there is a chance that your car still has the original parts on it.
Preventive maintenance is the joy of owning a Z3
Hope you sort it out.
The fan should have some resistance it will move both ways though. When everything is cold it should be faily stiff if you push it round it should not move freely. If it is then it may be part of the issue.
