'97 1.9l cooling refresh
PeteTschantz
American Zeds
Clover, SC
I'm about to order all the parts, etc to do the cooling system on my '97. With ~47k on the odometer, should I just go ahead and replace the radiator?
thanks,
Pete
raymond
EAST SUSSEX
Z3M
The cooling fan has a nasty habit of breaking up and damaging the radiator so it is a good idea to replace the fan. Radiators are quite cheap on ebay but get the right coolant from BMW
Reactions: PeteTschantz
PeteTschantz
American Zeds
Clover, SC
ordered the BMW coolant. Mine just has the electric fan, should I look at replacing that?
PeteTschantz
American Zeds
Clover, SC
I understand. I'm saying the only fan on mine is the electric fan.... and it is behind the radiator
As long as your electric cooling fan cuts in and out as it should when up to temp. and also is quiet, ie. bearings not noisy, I would leave it alone. Re the radiator, personally I would back flush it with water and take note how much sludge comes out. I suspect at that mileage it will soon run clear, again, I would keep it. Water pump, thermostat and drive belt , tensioner and idlers I would replace.
I had a 2.0 6 cyl. Pete and the aux. belt idler pulley bearings got very noisy, very quick and was like a new car with that done with a new belt. Amazing how noisy old poly-vee belts get with age. Amazing how much HP is used driving a belt driven cooling fan, an electric fan frees up a lot of extra horses. A job I had back in the 70's saw me removing belt driven fans and fitting electric fan kits at a UK Chrysler garage on several models, the first of the "modern " upgrades.
PeteTschantz
American Zeds
Clover, SC
thanks again Tony, I'm going to look at the idlers as well. Also needs new shoes, so I'm trying to be as efficient as possible...
Reactions: t-tony
Just try to do things in the order of most importance Pete. We're looking forward to coming over to our place in Fla. late October, hope we can skip the Hurricane this time. Be nice to have a chat when we're both on Eastern time.:)
