rmoconnor41
- Joined
- May 25, 2021
- Points
- 68
- Model of Z
- 2.8
Sold
I think it would have shown up on the various smoke tests. We can have another go but I think you are probably air tight now.One other thing. The smog pump was "enthusuiastically" removed one day and the blanking plate fitted. Is there anything leak wise I may have missed from its enthusiastic removal?
Thanks. Both of them?
Afternoon,
The vehicle is a 1999. 2.8.
For some time it has had a rough idle when cold. The revs swing between 800-400 until the vehicle is warm. Then the idle is very steady.
It is always throwing trim bank error codes . P0170 and P0173 Fuel trim bank 2 and 1 control limit.
MAF is newish
No air leaks. Thoroughly tested by the shed.
VANOS rebuilt
DISA and ICV checked.
Post CAT O2 sensors replaced.
Smog pump was removed and blanked off.
It threw a thermostat code on the shed's advanced code reader so that was replaced last week.
I am running out of things to check or replace.
Any thoughts?
Thanks
I have had a look online at cam sensor The price and range of brands is huge. Is the original made by Siemens.Thanks. Both of them?
