5k rpm limit bypass? Anything s possible
:welcome: from Gloucestershire
@lowliferoadster put some photos up quick or your likely to get whipped with wet nettles :whistle:
lowliferoadster
Wakefield
Roadster 2.8 manual
Since I bought the car, the abs and Asc have never worked, the lights aren't on on the dash ( I think the previous owner has simply covered the bulbs) . It doesn't bother me I like no abs or Asc but it's causing a 5k Rpm limit, is it possible to bypass it?
@lowliferoadster not me one area I don't touch:confused:, but someone will be along soon to offer advice I'm sure, loads of very knowledgeable Zedders here.:thumbsup:
Dino D
Kent
2.8 Manual
Getting the codes read for errors is probably a good start.
Z4 MR
Could be several issues, sadly bulbs being covered or removed are more common than you'd think - particularly with airbag lights.
As Dino says, first port of call would be to get the fault codes read with a reader that reads chassis codes.
littlefeller
evesham
welcome from Evesham, the asc could cause the lower rev limit, it does on later cars but i have not heard it on a Z, the usual way in motor sport to get around this kind of limp mode is to disconnect the asc, buy you wont be able to MOT the car without it. i dont like asc either but one day i might be glad i have it.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Hello from Truro
