Zorg
- Joined
- Jun 7, 2012
- Points
- 52
The new 2014 BMW M6 Gran Coupe is currently being tested in Germany by journalists from around the world (BMWBLOG’s own review will follow soon). Earlier today we brought you a video of the super sporty four-door M6 Gran Coupe running to 300 km/h on the Autobahn.
Along with the video, we are now giving a high-res photo gallery of the elegant and sporty Gran Coupe.
Under the hood, the M6 Gran Coupe features a high-revving V8 engine with M TwinPower Turbo technology that produces 560 hp and 680 Newton meters (502 lb-ft) on tap between 1,500 and 5,750 rpm, while maximum output is developed between 6,000 and 7,000 rpm. The engine revs to a maximum of 7,200 rpm.
Here is a list of some of the goodies developed for this car by the German engineers.
Chassis, Suspensions, Brakes
- Integral rear axle, double-wishbone front axle has specific kinematics and components made from forged aluminium
- Chassis mountings using large panels
- M-specific version of the Dynamic Damper Control system and hydraulic variable-ratio rack-and-pinion steering with the M Servotronic function
- Anti-lock Braking System (ABS) that includes Cornering Brake Control (CBC), Dynamic Brake Control (DBC), Brake Assistant, Brake Fade Compensation function, a Brake Drying function and Start-off Assistant.
- BMW M6 Gran Coupe can also be ordered with M carbon-ceramic brakes: The brake rotors measure 16.1 inches (410 mm) in diameter at the front and 15.6 inches (396 mm) at the rear.
- The M Carbon-Ceramic brakes are 42.8 lb (19.4 kg) lighter than the standard brakes
- The diameter of the standard brake rotors is 15.7 inches (400 mm) at the front and 15.6 inches (396 mm) at the rear.
Interior
- Two M Drive buttons which can be used to call up a pre-configured setup for the car.
- M Head-Up Display
- Lightweight seats with integrated belt system
The article 2014 BMW M6 Gran Coupe – New Photos appeared first on BMW BLOG
Continue reading...
