2001 Z3
hard top
Dutch Zeds
Netherlands
Welcome to the Forum Paul, I just had a quick look online and came up with this :-
M54B22, 2.2 L (2,171 cc), 125 kW (168 hp) at 6,100 rpm, 210 N⋅m (155 lb⋅ft) at 3,500 rpm ·
Snooks
Thanks 👍
The other thing is :
I’m taking my Z3 on a car trip to Spain in September, there’s 5 cars going with 10 drivers , I want to do a list of things to replace before I set off
Gaskets
Seals
Pipes
Etc …
My Z3 has done 93000 miles , full service history,
Any advice would be helpful ??
Pond
Spaldingski, Lincs
3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
Hi and welcome.
One pair of my grandparents lived in Abingdon for years and my sister is still in Wallingford.
Unless you are VERY lucky, your car will probably have some moisture inside it as it was sat in a garden and it's a Z3! ;) Take up the passenger seat front piece of carpet and check for moisture in the foam and if there is any sign, check the two DSC sensors under the black plastic cover on the floor.
These are the yaw and acceleration sensors for the DSC (dynamic stability control) and corrode and fail if sat in a damp or wet environment.
Yours should be OK at present, as it would fail an MOT if one or other (or both in my case) were faulty as the DSC light would not extinguish on the dash.
If they fail they are extremely expensive to replace (one is around £700 new, the other is £150).
Snooks
Thanks , much appreciated.
Another query I would like to know , is how much power difference is it with or with out the traction control button on ?
I didn’t realise that it makes a difference to be honest 🙃
Pond
Spaldingski, Lincs
When you say traction control button....a 2001 Z3 doesn't have a dedicated TC button as far as I know. If you are talking about the DSC, that just applies braking to each of the rear wheels independently to act like 'rear wheel steer' or a very simple LSD. No reduction in engine power as far I am aware.
Snooks
Z3 , 2001 , 2.2 straight 6 :)
Hi everyone , loving my Z3 , I've had it for 5 weeks now , getting used to driving it and what fun its .
I want to replace the four tyres , they have been on the rims for a long time, so I want to renew them .
front 225/45R17, rear 245/40R17
so the question I'm asking , what brand would you recommend ?
Thanks
Snooks
AntStark
Hampshire
2002 3.0 Sport
Really depends on your budget. Michelin Pilot 4 or 5 are a good top end tyre but with top end price. Many swear by Avon ZV7s as a good match for a Zed and they are good value too. Uniroyal rainsports are also a good midrange too
Snooks
Thanks, budget isn't an issue to be honest , so which one is the best for grip and low road noise , do you recon ?
Michelin Pilot Sport 5.
IanA
Oxon
Hi, Im based in Abingdon , Oxfordshire , any idea where or if there are any Z3 meet ups near me ??
Just seen this...the breakfast meets (from 09:30 on the 1st Thursday of every month) at Milletts Farm garden centre are popular with any make of car. I usually take a Z3 re-body. There was a Tribute 250SWB from Witney there this month.
The Witney Motor Show (evening event) takes place on the 1st Thursday in July.
Keith Crews
Hi and welcome.
Yes my light has been on for a year now ,i may not care to replace parts if so expensive! I am going to check under rug ,it does get wet1
