2 button remote dead - disable alarm?
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Hi Martin
Found 3 on Ebay that look the same on the outside but you will need to ask them to show you a pic of the inside to see if it is same as yours. The first one that I purchased the other year looked the same but was different inside
2 button remote £12.95 Ebay item 253978587926
£18.49 Ebay item 153235869946
£34.99 Ebay item 183501909499 comes with a spare key ? and an alarm key
I hope you get it sorted
Geoff
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
Got dorted on this today after purchasing a fob from ebay.
Had to get the glove box out and alarm module out. You can slide off the receiver module to access some pins which, when you short the right ones, disables the alarm by simulating a signal from the right fob. Despite instructions from the Web this didn't lock / unlock the doors but only activated the alarm
I could then move the switch to learning mode and set the second hand fob.
Thanks for the advice!
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
I could then move the switch to learning mode and set the second hand fob.ess
Did you buy one of the fob details I sent ? I only took out glove box to gain access to switch them followed site instructions to re code fob then sorted
Mnbrennan
Aylesbury
I got the £12.49 one. I only took out the module to disable the alarm
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Great glad your sorted
Ravz3
Maybe the alarm has desynchronised from the fob. Do you have the alarm manual with the little yellow envelope? If so it has a code inside on a card that you can input to resync the alarm.
Where do you put the code
motco
Chilterns
Z3 2.2i Sport
I've only just seen this thread. My manual says that if you unlock the door with the key in the lock, the alarm will go off after a period. However, if you put the key in the ignition and turn it to 'run' within a minute or so, the alarm will not go off. Mine is a late 2002 2.2 Sport
