2.8 PRE FACELIFT OBC
Antm72
South Yorkshire
Can anyone advise is the ppp error code on an obc terminal or is it going to related to another issue, it appears that it failed after the car was dry stored and the battery was disconnected prior to this it had worked fine . Any input would be good before i shell out for a replacement thanks in advance
Yeah just ppp doesn't even go off when the cars ignition is off stays lit and displays ppp believe its lost its coding ? Its a spurious fault very little on line can be found so thought id experiment with it and see if i can find an answer .
From what i have read its scrap it and get another but no answer to cause . It mentions voltage drop and suceptability to possible damage but then it also says its just lost the car info and only bm can resolve any info would be greatly recieved .
