Simon Blythe
110k mate - needs all the fluids doing
Cheers Tony, when it comes to refilling, what's the best way?You will need to be able to lift all four corners of the car Simon so that you have it sitting level to drain it and more importantly to refill to the correct level. Also make sure you can remove the filler/level plug BEFORE draining the old oil.
I have two trolley jacks and a pair of axle stands. I start by lifting under the diff. casing using a rubber pad to protect the diff. When high enough I put stands under the rear jacking points on the sills. When lowered onto the stands I place the two jacks under the front jacking points and lift until the car is level.
Hi Simon, a lot of people use the squeezy, squirty bottle which you buy the oil in but this is a very messy and wasteful way of doing it. I use a large (approx. 1 ltr.) syringe to fill the gearbox. we recently bought one at work from Andrew Page (Lincoln) which is a Sealey product and available on eBay amongst other sellers. This is the cheapest one I found, these are 200ml. capacity.Cheers Tony, when it comes to refilling, what's the best way?
Good old Andrew Page - just off Tritton Road?Hi Simon, a lot of people use the squeezy, squirty bottle which you buy the oil in but this is a very messy and wasteful way of doing it. I use a large (approx. 1 ltr.) syringe to fill the gearbox. we recently bought one at work from Andrew Page (Lincoln) which is a Sealey product and available on eBay amongst other sellers. This is the cheapest one I found, these are 200ml. capacity.
http://www.ebay.co.uk/itm/222274295194?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
These are also useful for emptying the brake fluid resevoir or power steering etc.
That's the one, you know it?Good old Andrew Page - just off Tritton Road?
Yes mate, I used to live in LincolnThat's the one, you know it?
It is Tracy and it stinks to high heaven!!Getting my gearbox oil changed out of precaution as it's a 1997 and has never been done as far as I am aware no proof on the service bills.
Great job. certainly looks black.
