Just spotted this on PistonHeads - https://www.pistonheads.com/buy/auction/20867416
Will be interesting to see what it goes for
Not surprising really, as it has a lot of miles, not good SH and an oil leak. S engines need to be looked after more than most.£9,250 but didn’t meet reserve
I mostly agree with you but don’t think that they couldn’t afford to run it - just didn’t care that much. I’m sure they didn’t, for example, spend days thinking about spring rates and bush material, oil grades and shelf lives. They’d never fit in around these parts.It's not just the car that's shiny on top
The last Inspection 2 was at 29,000.
The car will be easy to rescue. It's got lots that needs addressing, and most people wouldn't bother with. Lots of simple things, like sorting the seatbelt guide, the aerial, the handbrake gaiter and the driver's foot rug are easy, and should have been done. I suspect the radio doesn't work, or it would have been shown working. The other stuff is the stuff you don't see - the stuff that makes these cars different.
These need an Inspection 2 every fourth service (36,000miles ish) if you are going to get the best out of them. Diff oil should have been changed at least once, probably twice, but no evidence of a change.
This owner has bought a car they can't afford to run, but then when they do spend money on it, they spend far too much. He even spent £12 having fuel the last time it was in the garage. I'm looking for a viscous coupling, but I'll be spending £40-£50, not £200.
Comments about ride height after new springs and dampers fitted, but this could be due to several things. I'd double-check the spring part numbers with BMW. You can't check spring part numbers on RealOEM.
I think he should take £10k, think himself "well shot".
Spot on.I’ll keep my m44 which offers me 95% of the pleasure and 10% of the frustrations of owning an M Roadster.
