Just run in Steve. What's up with the Skud, ABS pump?
No decided the other night at some point after i had parked it to have a massive seal fail on the offside rear caliper so the following morning had emptied the hydraulic system.
Took the zed to work had a look that night worked out caliper failed.
Got new caliper next day ( yesterday) brought home pressure bleeder as well fitted last night in the baltic cold jacked up in the street in the dark all 4 wheels off for caliper and 4 wheel bleed.
Got the brakes back up but still spongy after 2x pressure bleeding .
So tonight back at it again brought home the diag computer stopped off to buy 4ltr of brake fluid ( knew I'd be needing a lot for what i was about to do).
So got home carried out a full abs electronic bleed 3ltr brake fluid later brakes restored air lock removed.
