100k Day
Jjim
Mansfield
1.9 Roadster
Congratulations on the landmark! Now you have a lot of zeros to count up from again :thumbsup:
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
I feel your pain Steve. Mine turned 100k just before I put it to bed for winter.
Just run in Steve. What's up with the Skud, ABS pump?
................. and I bet you've hated every one eh Mike? :D Like Steve's only just run in.
No decided the other night at some point after i had parked it to have a massive seal fail on the offside rear caliper so the following morning had emptied the hydraulic system.:mad::mad::mad: Took the zed to work had a look that night worked out caliper failed.:grumpy:
Got new caliper next day ( yesterday) brought home pressure bleeder as well fitted last night in the baltic cold jacked up in the street in the dark all 4 wheels off for caliper and 4 wheel bleed. :meh:
Got the brakes back up but still spongy after 2x pressure bleeding .:mad:
So tonight back at it again brought home the diag computer stopped off to buy 4ltr of brake fluid ( knew I'd be needing a lot for what i was about to do).:confused:
So got home carried out a full abs electronic bleed 3ltr brake fluid later brakes restored air lock removed. :)
2.2 Sport Individual
You've a bit to go to catch me. Just a smidge under 180,000 now:whistle:
