So after a long running saga and a few trips to ZshedWest over the winter, I have finally got the MOT on my Z.
The MOT initially expired on 4th September, so I put it in for a test in mid August, not expecting too much to come back. First attempt:
This did not seem too bad. Headlight beam, OK tester can adjust. Rear fog lamp just sticky and works fine now. Front suspension joint acquired and with ZshedWest efforts fitted (both sides because I like symmetry).
Re-test booked for mid October, expecting an easy Pass, but no:
Another trip down to see @Nodzed in Lydney, ably assisted by @colb. Both anti roll links replaced and with @colb's box of tricks diagnosed the emission issue as a Crankshaft sensor. MIL light was a non issue and Nearside position lamp was a bulb replacement. Headlight adjustment as before.
So the Crankshaft sensor was a right royal pain in the posterior, initially supplied the wrong one by Cotswold BMW, so had an aborted day whilst we worked that one out. In between all this, I had to replace the rear tyres after the nearside one shredded on a trip to the Zedshed. We also replaced the radiator as the one in the car had bowed significantly and did not look 'stable'. Then the 'Stability Control' light came on, which was a new fault but also an MOT fail.
Any crankshaft sensor finally fitted. Booked into Independent BMW garage for next MOT to ask if they could diagnose and fix the Stability Control issue, we thought it may be the speed sensors.
Another day another MOT:
So the stability control was fixed (actually a Throttle body Actuator fault). And they also fixed the rear brake issue. So now it is just the damned headlights - and now both sides. The garage could not get the lights to adjust, adjuster knobs seized and failing. They recommended new headlights - bugger! Anyway another convo with @Nodzed and another morning in Lydney. We (well Niall mostly) removed both headlights, freed up the mechanisms, fixed the rotating knobs and re-assembled.
Took the car back in today for the re-test:
There are some advisories, but they can now be done at leisure and I have a car I can use over the summer.
Thanks to @Nodezed, @colb and Martin (Niall's son) who all contributed to this outcome, I am extremely grateful.
