I took our drivers seat out today to change a trim piece. The process i did was the following.
1. Slide the seat back and remove nut caps and untighten the front 2 nuts.
2. Slide seat forward untill it clears the rear bolts then undo
3. Remove the bottom seat belt anchor Bolt
4. Undo the 3 torques screws that hold the seat belt guide
5. Drop the roof
6. Disconnect Battery +
7. Unplug the connector lead under the seat. This has a push in holder slide it out and then unplug
8. Remove Seat.
To refit
Replace seat and fit the plug back on connect battery and then re fix the nuts and bolts.
No code needed for radio but you will need to reset the time you may also need to reset the windows. I have this to do on mine which will be tomorrow as i noticed when putting hood up the windows did not complete their cycle
