Z4 Roof problem
Rob Hyslop
Z4 roadster roof!
Took the roof out and replaced the motor, replaced the roof and roof only works one way, if I change the wires over in the left rear quarter panel using line out cables then the roof works the other way as if there’s only one supply going to the motor, I have replaced the centre console switch in the first instance but doesn’t rectify the problem, all fuses have been checked and blown ones replaced where necessary. When the roof closes fully there is a red flashing light, the car is a 53 Reg, any ideas? All in all the roof motor works open and shut but only with swapping the wires over.
Rob Hyslop
Hi, thanks for that, I’m sure that switch has to work for up and down as you need to put the rear shelf down to operate the roof?
