Had the car in for a MOT and it failed on the lower susp.arm ball joint and hand brake lever. The ball joint is worn and apparently you can push the handbrake lever down from the locked upper position. How easy is it to replace the ball joint any special tools needed? The handbrake lever is a bit strange, unusual to wear I would have thought, none for sale on eBay anyway.
