Z3m stereo
Andy Birts
Hi. I have a z3m roadster with only 24000 miles on it. I could either do with finding a cd changer for the boot and the wiring that it would require or rather buy a modern stereo that would take a USB. It currently has the upgraded supplied stereo with sub but I am wondering what modern type of stereo would just pop in bearing in mind I think mine will have an amp built in somewhere any thoughts please ?
bertiejaffa
Manchester
Z3M
I bought just a nice stereo that I likes that had Audio Bluetooth etc and fitted it to the car using the existing wiring - obviously didnt connect anything to do with the multichanger. I also upgrade the OEM speakers to have greater wattage than the stereo to ensure the sound didnt crackle when loud.
Andy Birts
Hi. My problem is I need a low wattage output stereo because it has to then go through the upgraded amp which mine has from new apparently.
Andy Birts
Driving to southern Spain in it so could do with getting it right really. Proving to be ultra difficult.
137699
Hampshire
M Coupe 3.2 S50
You can add Bluetooth/USB to the original stereo using the CD changer port.
Much better than buying a modern stereo because...
1. Looks period - modern radios look gash
2. Lights up the correct colour
3. Sounds better as it connects up all the amps etc where as many of the aftermarket wiring kits bypass them
4. Not going to come back and find a brick been put through your window to steal the stereo
This is the kit I used:
Bluetooth A2DP Handsfree USB SD AUX Adapter for BMW e46 e39 Round Pin: Amazon.co.uk: Electronics & Photo
Andy Birts
Bloody hell. Will look into this when I get home. You are a lifesaver if this works for me.
Sean d
Lincolnshire
There are some very good car stereos out there that look period, and not "gash" as someone kindly pointed out they also sound far superior and have all the modern facilities, especially when the speakers are upgraded, the original HK system sounds bloody aweful
137699
Hampshire
M Coupe 3.2 S50
Sorry but the HK system sounds really good - WHEN powered properly by a genuine BMW radio.
My own Z came with a “gash” but expensive Sony unit installed. Spent weeks trying to get a decent sound output from it.
Then I trial fitted a “period” original CD43 unit and the sound improvement was night and day over the Sony unit. Sure it didn’t have Bluetooth as it pre-dated that era but £50 later a Bluetooth module fixed that little issue - the display colour matches the rest of the dash, it looks correct (because it IS correct) and it’s highly unlikely to get stolen.
But for me, most importantly, it sounds really good. Absolutely nothing wrong with the HK setup - just needs the correct headunit to drive it properly.
