Wanted Z3M Gear Gaitor
Jjim
Mansfield
1.9 Roadster
I’ve got hold off a Z3M Centre console, but it did not have the gear gaitor.
As these are smaller than the normal gear gaiters due to the chrome ring around the hole I can not use my old one.
I am after a Z3M gear gaitor, doesn’t matter what colour or condition, as I need the fitting ring (which unfortunately I can’t seem to buy separately from BMW).
Any help would be greatly appreciated.
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
I might have one, but won't be able to check till the weekend
Jjim
Mansfield
1.9 Roadster
Thanks for letting me know :thumbsup:. No rush, as I’m away this week.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
Someone managed to cut down and modify the standard one to get it to fit but I can't find who and where now. I had one from a fellow member which he made with a 3D printer and it fits great. You may be able to cut down a standard one and make it fit, I can imagine they may be hard to get hold of second hand. Hopefully Martin has one you can use.
Antm72
South Yorkshire
You may be able to form one from a strip of aluminium, it won't be to bad a job :thumbsup:
Jjim
Mansfield
1.9 Roadster
Hi Martin, any luck with a Z3M gear gaitor?
If not no probs, I’ll look to try and fabricate one.
Mnbrennan
Aylesbury
Sorry, didn't get round to it! Will sort this weekend!
DavidM
Ireland
@Jjim - I have the chrome surround which you are welcome to - not sure how many screws are on the surround - I think there is one missing. I also have a black gaitor - with a bit of TLC it should be fine - let me know - no charge on both items.
David.
Jjim
Mansfield
1.9 Roadster
I have a old tatty gator but just checking it does not have the ///M stitching but your more than welcome to have it so you can use the base to play with if it’s not a straight fit.
Thank you for the offer. Is the gaitor for a normal Z3 or for a Z3M?
As the Z3M has a smaller gaitor size as it has to fit inside the chrome surround that is only on the Z3M.
David.
Thank you for the offer. PM sent.
