Z3cades S50 Progress Journal
z3cade
Messages
1,980
Peterborough
The new addition is my 98 S50 //M
The engine bay =p~
Macca
Messages
1,064
Wisbech St. Mary
2.5l Msport
Re: Z3cades S50 Thread
I can't wait to see it in the flesh Liam. Hope your bringing it to the Feb meal.
Macca
Messages
1,064
Wisbech St. Mary
2.5l Msport
badman gee said:
richard, you will see it in the metal and will have to settle for that!!!!!!!
Ooooo, very good. you coming in yours Mark?
EnthuZiaZT
Messages
4,696
Heacham Norfolk
Z4 28i Msport
Oh no, looks like I shall have to get to work on ours now, just to keep up the the Jones's s:rolleyes
Looks good in the pics. Liam. Hoping for good Feb weather for spotting Zeds and walking in Sandringham. s:mrgreen
z3cade
Messages
1,980
Peterborough
Thanks for your comments guys, can we keep this thread just on my car progress please, hence why I've started a new journal thread, Ta. ;)
EnthuZiaZT
Messages
4,696
Heacham Norfolk
Z4 28i Msport
Sorry Liam, Will do.
Have you decided whether you are going to change the colour of the wheels back to standard or not yet?
z3cade
Messages
1,980
Peterborough
Dont worry ;) No i think the car is going to stay as it is for the moment as the wheels are perfect condition and it would be a waist of money changing them back.. plus i love the finish of them with the Estroil fleck, its nice to be different
B
badman gee
Guest
you are different mate ;)
z3cade
Messages
1,980
Peterborough
After surfing the net i managed to find some instructions for the Alpine headunit that came with the car and found out the illumination could be changed.. The blue was to bright at night but the red matched the rest of the dash lights... result!!
z3cade
Messages
1,980
Peterborough
Sill removal and rust prevention
Today the sills were removed so i could remove the mud and muck that had collected over the years on the sills, i also treated the areas so there should be no problems in the future for rust s:mrgreen
Sill removal
Jack up the car and place on axle stands
Remove wheels
remove rear arch liner
Remove kick pannel trim and door rubber
remove kick pannel plastic plug
Remove kick pannel by lifting up
You may brake some plastic clips so remove broken clips from holes
Remove front arch liner
Remove screw from front arch, top front of sill (use 10mm ratchet)
Remove three screws for the small side pannel, detatch side repeater and remove
Get a friend to help, but a good friend not a nutter... s:rolleyes
Remove screws from under the sill
Remove screw from rear arch
Remove small plastic trim from inside door and remove bolts that hold rear arch to allow better access for the screw behind it
Remove final bolts from top of the sill that were under the kick pannel and remove sill
Clean up box section and check for rust
Treat areas with rust with your prefered products
I used zinc 182 primer, clear waxoyl spray for inside box sections and original waxoyl underseal
Treated rear box section
Treated front box section
Sand down any rust found on the sill and treat with your desired products
Now just reverse the removal process and replace the sill, Job done :-bd
Luckly mine wasnt bad at all with rust but im glad ive done them so its now protected for the future.. i would recomend doing them
z3cade
Messages
1,980
Peterborough
Fitted today are my new gaitors with blue stitching and a Storm lighter plug to finish off the center console :x
shantybeater
Messages
202
Great job on the sills liam, noticed last night whilst changing my rear brake pads that a bit of surface rust is showing. I think I will be carrying out the same job at some point soon. Did the panels all line up ok when you put the car back together?
Car looks mint BTW and the storm bits get a thumbs up from me
B
badman gee
Guest
we did mine shanty last week
the panels line up, but you need to pay attention when you do it.
its a job worth doing on all the zeds.
mark
