Put a straight edge vertically on the wheel arch and measure the distance across to the top of the wheel rim, this will give you an idea of the size required.
Mine is off the road for the moment for its winter update and I managed to get new wheels fitted. To get the spacing perfect I removed the rear spring and jacked the suspension up to the stops and measured the fitment. If you have the space its pretty easy to remove the rear spring and have a look before ordering spacers.
At full stuff I have a few mm of space and nothing rubs at all. And its about as close as its going to get.
